title: VM-IL Series - 3 Axis Vertical Machining Centers
[![Milltronics](https://info.milltronics.com/hs-fs/hubfs/Milltronics_USA_Logo-no-tagline.jpg?width=340&height=50&name=Milltronics_USA_Logo-no-tagline.jpg)](https://info.milltronics.com/europe?hsLang=en)
- [Home](https://info.milltronics.com/europe?hsLang=en)
- Milling
    - [Tool Room Mills](https://info.milltronics.com/vm-trm-series-tool-room-mill?hsLang=en)
    - [General Purpose VM Series Vertical Machining Centers](https://info.milltronics.com/vm-series-3-axis-vertical-machining-centers?hsLang=en)
    - [Performance IL Series Vertical Machining Centers](https://info.milltronics.com/vm-il-series-3-axis-vertical-machining-centers)
    - [Performance XP Series Vertical Machining Centers](https://info.milltronics.com/vm-xp-series-3-axis-vertical-machining-centers?hsLang=en)
- Turning
    - [Combo Lathes](https://info.milltronics.com/ml-series-tool-room-combo-lathes?hsLang=en)
    - [SL Series Slant Bed CNC Lathes](https://info.milltronics.com/sl-series-slant-bed-lathes?hsLang=en)
- [Control](https://milltronics.com/cnc-control/)
    - [CNC Control](https://milltronics.com/cnc-control/)
    - [Productivity Software](https://milltronics.com/productivity-software/)
- [Help Center](http://support.milltronics.com/)
- [DGI Desktop](https://milltronics.com/dgi-desktop/)
- [News & Media](https://milltronics.com/latest-news/)
    - [About Us](https://milltronics.com/about/)
    - [Video Library](https://milltronics.com/video-library/)
    - [Articles & Product Literature](https://milltronics.com/latest-news/)
# VM - IL Series | 3-Axis Mills
 English
- [English](https://info.milltronics.com/vm-il-series-3-axis-vertical-machining-centers)
- [Deutsch](https://info.milltronics.com/de/vm-il-series-3-axis-vertical-machining-centers)
- [Italiano](https://info.milltronics.com/it/vm-il-series-3-axis-vertical-machining-centers)
# PERFORMANCE IL VERTICAL MACHINING CENTERS
The IL Series machines have inline spindles, roller guides for rigidity, directcoupled ballscrews for quick response,
and dual wound spindles for faster acceleration/deceleration.
| VM-IL series models | VM-3018IL | VM-4222IL | VM-5025IL | VM-6030IL |
| Table working surface | 860x460mm | 1,170x560mm | 1,370x635mm | 1,680x760mm |
| X axis working stroke | 760mm | 1070mm | 1,270mm | 1,525mm |
| Y-axis working stroke | 460mm | 560mm | 635mm | 760mm |
| Z-axis working stroke | 560mm | 610mm | 610mm | 610mm |
| Spindle power / torque | 18Kw / 115Nm | 18Kw / 115Nm | 26Kw / 165Nm | 26Kw / 165Nm |
| Spindle r.p.m. | 10,000 rpm 15,000 rpm option | 10,000 rpm 15,000 rpm option | 10,000 rpm 15,000 rpm option | 10,000 rpm 15,000 rpm option |
| ATC capacity | 30 tools | 30 tools | 30 tools | 30 tools |
| Machine weight | 4,850 kg | 6,700 kg | 8,120 kg | 9,900 kg |
| Machine height and footprint | H 3,025 mm | H 3,060 mm | H 3,100 mm | H 3,125 mm |
|   | L 2,180 mm | L 2,800 mm | L 3,250 mm | L 3,810 mm |
|   | W 2,685 mm | W 2,935 mm | W 2,620 mm | W 2,920 mm |
| Contact your local representative to learn more about options and accessories available for each machine model |  |  |  |  |
![Milltronics_Icon](https://info.milltronics.com/hubfs/Milltronics_Icon.png)
[Basisweg 10 1043 AP Amsterdam The Netherlands](https://goo.gl/maps/6y3Gxhx8XRmr4PNk7)
### MILLS
- [Tool Room Mills (TRM)](https://info.milltronics.com/vm-trm-series-tool-room-mill?hsLang=en)
- [General Purpose Machining Centers (VM)](https://info.milltronics.com/vm-series-3-axis-vertical-machining-centers?hsLang=en)
- [Performance Machining Centers (IL)](https://info.milltronics.com/vm-il-series-3-axis-vertical-machining-centers)
- [Performance 50 Taper Machining Centers (XP)](https://info.milltronics.com/vm-xp-series-3-axis-vertical-machining-centers?hsLang=en)
### LATHES
- [Combination Lathes (ML)](https://info.milltronics.com/ml-series-tool-room-combo-lathes?hsLang=en)
- [Slant Bed Lathes (SL)](https://info.milltronics.com/sl-series-slant-bed-lathes?hsLang=en)
- [Dealer Login](http://dealers.milltronics.com/)
- [Terms of Use](https://milltronics.com/terms-of-use/)
- [Privacy Policy](https://milltronics.com/privacy-policy/)
© 2022 Milltronics. All rights reserved
