title: ML Series
description: The ML Series of combo lathes can be run as manual, teach, or full CNC. They feature easy thread repair and are available in more than 15 sizes.
[![Milltronics](https://info.milltronics.com/hs-fs/hubfs/Milltronics_USA_Logo-no-tagline.jpg?width=340&height=50&name=Milltronics_USA_Logo-no-tagline.jpg)](https://info.milltronics.com/europe?hsLang=en)
- [Home](https://info.milltronics.com/europe?hsLang=en)
- Milling
    - [Tool Room Mills](https://info.milltronics.com/vm-trm-series-tool-room-mill?hsLang=en)
    - [General Purpose VM Series Vertical Machining Centers](https://info.milltronics.com/vm-series-3-axis-vertical-machining-centers?hsLang=en)
    - [Performance IL Series Vertical Machining Centers](https://info.milltronics.com/vm-il-series-3-axis-vertical-machining-centers?hsLang=en)
    - [Performance XP Series Vertical Machining Centers](https://info.milltronics.com/vm-xp-series-3-axis-vertical-machining-centers?hsLang=en)
- Turning
    - [Combo Lathes](https://info.milltronics.com/ml-series-tool-room-combo-lathes)
    - [SL Series Slant Bed CNC Lathes](https://info.milltronics.com/sl-series-slant-bed-lathes?hsLang=en)
- [Control](https://milltronics.com/cnc-control/)
    - [CNC Control](https://milltronics.com/cnc-control/)
    - [Productivity Software](https://milltronics.com/productivity-software/)
- [Help Center](http://support.milltronics.com/)
- [DGI Desktop](https://milltronics.com/dgi-desktop/)
- [News & Media](https://milltronics.com/latest-news/)
    - [About Us](https://milltronics.com/about/)
    - [Video Library](https://milltronics.com/video-library/)
    - [Articles & Product Literature](https://milltronics.com/latest-news/)
# ML Series | Combination Lathes
 English
- [English](https://info.milltronics.com/ml-series-tool-room-combo-lathes)
- [Deutsch](https://info.milltronics.com/de/ml-series-tool-room-combo-lathes)
- [Italiano](https://info.milltronics.com/it/ml-series-tool-room-combo-lathes)
# TOOL ROOM COMBO LATHES
| ML- series models | ML16 | ML18 | ML22 | ML26 |
| X axis working stroke | 280 mm | 300 mm | 330 mm | 330 mm |
| Z-axis working stroke | 1,130 mm | 1,600 mm | 1,600 mm | 1,070 - 4,140 mm |
| Spindle power / torque | 11Kw / 147Nm | 15Kw / 306Nm | 18Kw / 1400Nm | 18Kw / 1700Nm |
| Spindle r.p.m. | 4,000 rpm | 2,600 rpm | 2,000 rpm | 1,600 rpm |
| ATC capacity | 8 tools | 8 tools | 8 tools | 8 tools |
| Machine weight | 2,730 kg | 3,850 kg | 4,500 kg | 4,300 - 7,800 kg |
| Machine height and footprint | H 2,030 mm | H 2,030 mm | H 2,100 mm | H 2,108 mm |
|  | L 3,050 mm | L 3,510 mm | L 3,630 mm | L 3,200 mm/L 6,250 mm |
|  | W 2,100 mm | W 2,100 mm | W 2,100 mm | W 2,133 mm |
| Contact your local representative to learn more about options and accessories available for each machine model |  |  |  |  |
![Milltronics_Icon](https://info.milltronics.com/hubfs/Milltronics_Icon.png)
[Basisweg 10 1043 AP Amsterdam The Netherlands](https://goo.gl/maps/6y3Gxhx8XRmr4PNk7)
### MILLS
- [Tool Room Mills (TRM)](https://info.milltronics.com/vm-trm-series-tool-room-mill?hsLang=en)
- [General Purpose Machining Centers (VM)](https://info.milltronics.com/vm-series-3-axis-vertical-machining-centers?hsLang=en)
- [Performance Machining Centers (IL)](https://info.milltronics.com/vm-il-series-3-axis-vertical-machining-centers?hsLang=en)
- [Performance 50 Taper Machining Centers (XP)](https://info.milltronics.com/vm-xp-series-3-axis-vertical-machining-centers?hsLang=en)
### LATHES
- [Combination Lathes (ML)](https://info.milltronics.com/ml-series-tool-room-combo-lathes)
- [Slant Bed Lathes (SL)](https://info.milltronics.com/sl-series-slant-bed-lathes?hsLang=en)
- [Dealer Login](http://dealers.milltronics.com/)
- [Terms of Use](https://milltronics.com/terms-of-use/)
- [Privacy Policy](https://milltronics.com/privacy-policy/)
© 2022 Milltronics. All rights reserved
