title: VM-XP Series - 3 Axis Vertical Machining Centers
[![Milltronics](https://info.milltronics.com/hs-fs/hubfs/Milltronics_USA_Logo-no-tagline.jpg?width=340&height=50&name=Milltronics_USA_Logo-no-tagline.jpg)](https://info.milltronics.com/europe?hsLang=en)
- [Home](https://info.milltronics.com/europe?hsLang=en)
- Milling
    - [Tool Room Mills](https://info.milltronics.com/vm-trm-series-tool-room-mill?hsLang=en)
    - [General Purpose VM Series Vertical Machining Centers](https://info.milltronics.com/vm-series-3-axis-vertical-machining-centers?hsLang=en)
    - [Performance IL Series Vertical Machining Centers](https://info.milltronics.com/vm-il-series-3-axis-vertical-machining-centers?hsLang=en)
    - [Performance XP Series Vertical Machining Centers](https://info.milltronics.com/vm-xp-series-3-axis-vertical-machining-centers)
- Turning
    - [Combo Lathes](https://info.milltronics.com/ml-series-tool-room-combo-lathes?hsLang=en)
    - [SL Series Slant Bed CNC Lathes](https://info.milltronics.com/sl-series-slant-bed-lathes?hsLang=en)
- [Control](https://milltronics.com/cnc-control/)
    - [CNC Control](https://milltronics.com/cnc-control/)
    - [Productivity Software](https://milltronics.com/productivity-software/)
- [Help Center](http://support.milltronics.com/)
- [DGI Desktop](https://milltronics.com/dgi-desktop/)
- [News & Media](https://milltronics.com/latest-news/)
    - [About Us](https://milltronics.com/about/)
    - [Video Library](https://milltronics.com/video-library/)
    - [Articles & Product Literature](https://milltronics.com/latest-news/)
# VM-XP SERIES | 3-AXIS MILLS
 English
- [English](https://info.milltronics.com/vm-xp-series-3-axis-vertical-machining-centers)
- [Deutsch](https://info.milltronics.com/de/vm-xp-series-3-axis-vertical-machining-centers)
- [Italiano](https://info.milltronics.com/it/vm-xp-series-3-axis-vertical-machining-centers)
# EXTRA POWER VERTICAL MACHINING CENTERS
XP Series VMCs are #50 taper machines built with robust cross rollers and high torque dual speed spindle motors.
| VM-XP series models | VM-5025XP | VM-6030XP | VM-8434XP |   |   |
| Table working surface | 1,370x635mm | 1,680x760mm | 2,185x865mm |   |   |
| X axis working stroke | 1,270mm | 1525mm | 2,135mm |   |   |
| Y-axis working stroke | 635mm | 760mm | 865mm |   |   |
| Z-axis working stroke | 610mm | 610mm | 760mm |   |   |
| Spindle power / torque | 26Kw / 495Nm | 26Kw / 495Nm | 26Kw / 495Nm |   |   |
| Spindle r.p.m. | 8,000 rpm | 8,000 rpm | 8,000 rpm |   |   |
| ATC capacity | 30 tools | 30 tools | 30 tools |   |   |
| Machine weight | 9,130 kg | 10,100 kg | 16,940 kg |   |   |
| Machine height and footprint | H 3,124 mm | H 3,124 mm | H 3,616 mm |   |   |
|   | L 3,250 mm | L 3,810 mm | L 7,575 mm |   |   |
|   | W 2,630 mm | W 2,920 mm | W 4,000 mm |   |   |
| Contact your local representative to learn more about options and accessories available for each machine model |  |  |  |  |  |
![Milltronics_Icon](https://info.milltronics.com/hubfs/Milltronics_Icon.png)
[Basisweg 10 1043 AP Amsterdam The Netherlands](https://goo.gl/maps/6y3Gxhx8XRmr4PNk7)
### MILLS
- [Tool Room Mills (TRM)](https://info.milltronics.com/vm-trm-series-tool-room-mill?hsLang=en)
- [General Purpose Machining Centers (VM)](https://info.milltronics.com/vm-series-3-axis-vertical-machining-centers?hsLang=en)
- [Performance Machining Centers (IL)](https://info.milltronics.com/vm-il-series-3-axis-vertical-machining-centers?hsLang=en)
- [Performance 50 Taper Machining Centers (XP)](https://info.milltronics.com/vm-xp-series-3-axis-vertical-machining-centers)
### LATHES
- [Combination Lathes (ML)](https://info.milltronics.com/ml-series-tool-room-combo-lathes?hsLang=en)
- [Slant Bed Lathes (SL)](https://info.milltronics.com/sl-series-slant-bed-lathes?hsLang=en)
- [Dealer Login](http://dealers.milltronics.com/)
- [Terms of Use](https://milltronics.com/terms-of-use/)
- [Privacy Policy](https://milltronics.com/privacy-policy/)
© 2022 Milltronics. All rights reserved
